T
tollen77
It's the other way around it's the heat making the rpm bounce around......
As for 2 much weight you need weight to run at the motors factory calibrations. If the 800R is calibrated to peak at 8150 rpm your going to need the weight to acheive those rpm's. Weight is not an option
The addition of adding or subtracting clutch weight in the TRA primary should only be used for acheiving and maintaining peak rpm as you tune your sled. If i want to grab the belt harder im not going to add or subtract weight in the primary nor do i advise anyone else to do so.
2 thing could occur either you have 2 much finish on the primary spring or your ramp profile is to steep. When useing a steep profile ramp you slow the shift becuase it's harder for the roller to go up the steep ramp into higher shift ratios thus causing added friction in the process. Or you could also have a combination of both.
The TRA need weight between the ramps, roller/arms X 3 = 300 grams approx. to operate add 16 grams of pinweight to each roller and your near 340 grams of weight plus or minus.
each ramp 63 grams
each roller/ arm 34 grams
OT
I think we've covered this in previous threads. Suffice it to say, I agree with some of this and disagree with a fair amount (specifically your opinion on how ramps work). No need to get into the details again though.
