I have had guys come back to me saying "look what i've done with all the stuff I read from you"
These guys have plowed through everything I've typed that they could read or was available and in point form have cut/paste what is important in the topics.
Example of what I have done on this page...I just copied what I mentioned previously
-Spring force can determine rpms in either clutch. More spring force = higher rpms.
-Helix angle can determine shift rpms under w.o.t, Less helix angle = higher shift rpms.
-Lower helix angle "stalls the upshift" from the primary, you would see higher rpms.
@Dock I don't mean to be totally off topic here, But what causes clutch heat???
I have read papers by drive belt mfg's and automotive mfgs. Have findings from my own testing and calibrating. In my clutch book I site the quotes from such companies that write on the topic of "high system temps"
- The #1 cause of system high temperature is "RPM FLUCTUATION"
An engine has "rated rpms" An engine has "torque point rpms"
IF you run a system at less than rated rpms, THEN temperatures will increase. (The clutches stop upshifting - mph ceases to increase)
IF you run a system at more than rated rpms, THEN temperatures will increase. (The clutches stop upshifting - mph increases ONLY by virtue of increased engine rpm)
@C-Bolt He REALLY knows his CHIT!!!!!!
C-B, I only know the principles that's it. I don't know setups I can only recite a principle of the parts, just like what is bullet form above. ....and you can too, everyone can.
These principles are difficult to disprove although I know of one individual who will try hard to do so.
-IF you run a system at less than rated rpms, THEN temperatures will increase. (The clutches stop upshifting - mph ceases)
-IF you run a system at more than rated rpms, THEN temperatures will increase. (The clutches stop upshifting - mph increases ONLY by virtue of increased engine rpm)
These are details I live by, they are principles derived from the laws of how the parts work.
When you run the system, your sled and observe the tach, make your notes....you see something that is not right, you have a question "Why" ain't it right?
You go back to the principles and identify one of them to help you make a decision on what part to change with the capacity you have at that moment.
