figure bringing this back to the top might help out those with new sleds this year........................
3 derin washers, how placed, 1 on top then stack 2 on bottom or what?
AK, Thanks for the great post, I am still a little confused as to what set up to use for my elevations, what do you think would be the best set up for a 09 D8 163 with stock pipe and hps can, and a single slp set up ? as I have both. I run from 2 to 6000 ft, mostly around 4500 to 5500 ft. I am picking the sled up today with all the new up date's, do you think their will be anything we will have to do different because of the updates ?
Ak... when you say 68 gram mtx, is that the base weight? meaning empty or without the rivits. So total it is basically 71ish grams?
Is there anyone planning on running the new team tied secondary by slp?
would 19/43 as gearing work? not to much doglegg?
Had the shop do a clutch kit following most of AKSnowrider's clutching tips on here and WOW!!! That's why they call it a dragon
The next question is what RPMs should i be concerned with and start adding weights to keep them out of any danger zone?
Thanks!!!
Any new info from anyone on what setups are working for them this year? Im trying the 62-42-.46 helix, SLP green/pink spring, 68g MTX weights with 2g tip and 1g belly as per AKSNOWRIDER next weekend in revelstoke and i cant wait. Ill be sure to let everyone know how this setup works
