well..I started out with carls setup..62/42/.46 helix, stock springs and 2 delrins with belly buster weights for my elevations..still felt it was leaving some on the table so I went with slp's recommended setup for their pipe...still felt lacking so i did a mix and is what has performed best for me and my feel of what I want the sled to do..I run slp green/pink primary spring, 68 gram mtx weights with 2 grams in the tip 1 gram in the belly, (with .20 belt clearence in frnt clutch), secondary has 62/42/.46 helix, stock spring and 3 delrin washers..I clutch for 8300-8450 peak rpms with slp pipe(where I have found best performance on the hill)belt temps are low belts last and sled works very good in deep powder and really good on setup snow...you will have to experiment with what feels best for you..the single pipe seems to like more rpm then most run it at but the on hill performance is noticable with more rpms up to 8500...
How similar are the slp green/pink primary and the slp blue/pink primary springs?
I have both recommended setups and equipment (Carls and SLP) but no slp green/pink primary spring. Will I be able to get by with the blue/pink primary spring?
