I will second that...clutching sure makes a difference. Rons weights sure made a difference with the combination too
poo is your setup about the same as stews ?hows it working?
glad to hear you like it stew, I have a set of weights that I was supposed to send to ron about a month ago(can ya say work sucks sometimes)..Did it really help the top end pull when climbing? thats real close to my setup other then for the initial angle 64 vrs 62 and primary spring 165/344 vrs my 160/340..hows it do for belt/clutch temps? mine after repeated climbs you can hold the belt in hand and lay your hand on either clutch,,,
800poodragon,
What did you change on the skids; drivers etc to change out the track? Is the track ported or with full clips?
I have a set of Ron's weghts on my sled and have the bright green Team spring on order. Plan to ride it this week to test it out.
akrevrider
Is anyone still workin' on there set-ups? Just a couple ? For those who are gearing down to 19/45, when you state your track speeds are you accounting for the speedos being off from the gearing change? How much $ are Rons weights, and how do I get them? I run between 5000 and 7000 ft and turn between 8150 and 8350, 163 Challenger extreme. Sled is kickin but I think I could get more with some clutch work. What would a 54-40-46 w/ delrin washers do compared to a 56-42-36 stock set-up? I know most are using a steeper initial angle but I am lacking $ and I have the 54. I am running the pink/blue with stock weights and 19/42 w/ slp single and can. Any input is appreciated.
Gang...here is a performance example of changes in clutching.
Day one we had a 58/40/36 helix pulling 66 grams of stock 10 style weights in the 860. Max RPM we could net with this setup at 9000-10,000ft was 8100 sled felt fine appeared strong and ran heads up with a skidoo 860. What bothered me was that it also ran heads up with a really strong running Carls 800 so I knew there was a ton more in there.
We came back again but with a set of belly buster 64's and a helix set at 64/44/36 and now we are 10-15 sled lengths faster (THAT IS INCREDIBLE IN SLED TERMS) then before but still only able to pull 8150 max. It was consistant and hugely fast but there was still top end on the table. Even just 10 lengths is so unbelievable but you could keep on going. Sled felt exactly the same but the results were awesome. Simple weight and helix change over the same set of springs....makes you want to look at your setup even when you think you are all right watching R's. Proof as well that the Carl's Cycle theory of a bit more helix compensated with springs is a more effective faster setup in a like vehicle then others that are doing less helix and standard 10 weights. Found the exact same results on our 800 as well so it appears to be across the board when you find the combo.
Well I just sat down and read the entire thread. Great info!! It seems like everyone who is clutching their sleds and getting the most gains are the ones who have done some mods (pipes, cans, cold air intakes, reeds and etc).
Those weights you guys are talking about intrigue me, wondering if anyone has tried them on a bone stock sled.
Mine is an 09 155 and in deep snow it pulls about 8300 in deep snow pretty consistent (3000-7000 feet). I really love this sled and it seems to be pulling hard but my deep snow track speeds are only about 39-41 mph, I saw some were getting 50+ ?? that seems huge.
So i guess the questoin im throwing out there is this: has anyone tried these set ups on a bone stock sled? if so what happened?
Thanks in advance.
hillking.. I don't understand this comment with relation to my post.
"You are right , I'll keep the real results to my self, I just happen to own both."
aksnowrider...have you tried any aftermarket can with the stock pipe...and then have you also tried to get back some of the RPM's with clutching on the stock exhaust?
I wonder if the TS variance is RPM related and the system calls for higher RPM at top end which is in direct conflict with HP/TQ data from dyno runs which show significant fall off at the RPM's which we see in the field that result in faster TS and further distance covered in time duration vehicle.
What they want for RPM seems to be a critical issue but it hasn't been nailed yet or reported. One other slightly frustrating situation is that we saw some RPM variances between the stock Polaris gauge and a datalogger gauge on the same vehicle. That was bothersome!
Great post here!!!
I have a '08 D8 163 and run at 7,000 feet and higher.
I bought a SLP pipe/can from TriCityPerformance and the dude behind the counter gave me the components for clutching to go along with the SLP kit. 58-38.46 helix, MTX weights (Added 2g tip 1g inside), Blue w/ pink and black w/ white springs. He said it would be perfect.
I set everything up and can only pull 7800 RPMs. The sled felt fine but didn't have the extra power. It basically went to sleep since the stock setup ran "much" better than the new setup.
I went on a family trip for Easter to Boise and HAD to stop at Carl's Cycle to see what the hype was all about. I explained my situation to a "clutching expert" and he recommended I do the following.....
Install a 62-42.40 helix, use the stock primary/secondary springs, add 2 delrin washers and use 60g BellyBuster weights. I bought all the stuff and have it ready for installation. This is COMPLETELY different than what was given to me at TriCityPerformance.
WHAT DO I DO?
Question for you guys: I have had problems with rpms & track speed like a lot of guys. Pulling a hill in a foot of powder i can't get any more than 36mph and 7700-8000rpm. I ride an 09' rmk 800 155" which is bone stock other than an aftermarket can. I have purchased 3-delron washers, a green/pink primary spring, mtx 68 gram weights, a dual sided helix (58/40/.36 or 62/42/.46), but can't decide on my sprockets? I have heard of people using a 19/46 and having good results. You said you use a 19/42, but i've been told that might not be a big enough increase from the stock 19/41? I couldn't find a 60/40/.36 helix so i went with the dual sided. I might have all of these helix numbers a little screwy so bare with me, but i think that's what i've been told. And i've been told a 19/45 or 19/43 sprocket setup is great, but then i've had a local mechanic say that polaris doesn't recommend those cuz it'll cause problems unless you use a 20 top with a 43 or 45 bottom? So i'm frikin' confused. I'd really appreciate your advice. Once again, my sled is stock, so i'm sure your slp single & reeds make a difference with your setup. Let me know though. Thanks alot.
