Hey Bryce,
Bit of quick info, I am running an HM turbo kit, 6.5psi boost with larger injectors (used in the 240hp kit.) I am running 50/50 (av/pump.) This setup has not been out on the mountain yet, was running 6psi stock injectors and straight pump gas last year but I don't recommend this.......
Can you please tell my what all is involved with installing a switch for data logging using the vipec?
Also I noticed in your write up that you recommend a fuel pressure regulator for turbo sleds, just curious why? From my understanding with 6psi you are reaching the limit for the duty cycle on the stock injectors. Is this recommended to keep the fuel pressure in check while running close to the limit of the stock injectors? I am not running a fuel pressure regulator, just curious if I should be? Again I am not well studied on the subject but with the larger injectors mapping should be able to sort out fuel pressure, and therefore it is not an issue?
Thanks for the great article
