I'm getting ECU code 005 on my 2016 M8000. The code is for an open or short in the air intake temp sensor. I have searched high and low and haven't been able to figure it out. Tried a new sensor even though the old one ohm'd out fine. I have continuity from the sensor plug to the plug at the ecu and everywhere in between. I have checked all the other pins with the ohm meter to and can't find another pin/wire that it's shorting against. using the ohm multi meter it doesn't appear to be ground to the chassis either. I checked the fuses and all was good there. I even checked all the spots that are accessible where the main harness is zip tied to the chassis thinking maybe a zip tie location had rubbed through a spot so I clipped the ties and opened up the loom and checked the wires in those locations. I did fine one that was rubbed 1/2 way through but it wasn't the air temp sensor wire, fixed that while I was in there. I even jumpered a wire from the sensor to the downstream side of the main plug at the console to eliminate a chance the plugs weren't making a good connection and I still have the code showing up. I'm about at a loss at this point.
Could the ECU or gauge be causing the issue. If not I'm pretty much out of ideas. Any help at this point would be great!
