Pro RMK Knee Pads
sdmc
How many of you have attached knee pads to your sleds? I'm thinking of doing it on my new sled and wondered if you thought it's a good idea.
The dealer showed us some rectangle pads that attached at knee level right in front of where you stand. They said that when your standing on the new sleds you get banged in the knees a lot. My previous sled was a 2004 and it was a non-issue. He also recommended having them cut like a triangle like area out of the bottom part of both side panels (where the 800 number was on the 2012 models) for venting. They have nice powder coated metal screens with frog skin on the back they rivet to the panels. He said it would improve air flow and keep the clutch cooler. Any thoughts from your experiences would be appreciated.
SDMC,
I managed to smack my right knee into the dash area hard enough to break an area the size of a softball in the plastic. I say this to make the point that whatever you put there should be tough.
Personally, I wear knee/shin guards to protect my knees. That way I have them protected off the sled too. Where the rubber pads on the sled will only help you on it.
Let us know what you choose!
Bag
Bagger
Thank you for your reply! I had my left knee rebuilt and maybe the guards are a better option. The dealer lead me to believe most have the pads attached to their sleds.
I would go with wearing knee pads as opposed installing them on the sled.
Bagger made a good point!
My Motor Fist pants have knee pads built into them. Their awsome. :face-icon-small-ton
Two seasons ago I bounced my knee/shin off my running boards. Hurt like a mf'er. Pulled my pant leg up and saw my tibia. 10 staples later, I always wear knee/shin guards from then on.
I always wear motocross shin pads. But I am installing knee pads on the sled to save the panels on the sled
I got a set. They are awesome in the trial. Specially going down hill. Call Shawn 435753 4936, that's where I got mine.
Have pads on my Doos but not this time on the Pro. Instead, I have the Holz rear panel, all aluminum, vent kit which strengthens AND vents that area and Klim pants with removable knee pads. Best of BOTH worlds!
Have FUN!
G MAN
Pads should be on your knees to protect your knees AND on your sled to protect the sled and for when your knee pads shift like ever style I have used always does.
If were putting on a MAXI PADS on your sled..
Where's the venting going?????
Looks like your engine compartment just got a little Hotter!
Going to put a Maxi Pad on Every tree too!!!!!!!??
knee braces
Knee braces yes they are more expensive but will save you're knees far more knee and shin protectors and knee pads for you're sled.
Knee Pads Good
I installed a set of the stock Polaris knee pads on my pro and with those combined with the pads in my Klim pants I love it. You can rest against the hood when you are going down hill and it works great. Highly recommend them. Try it you'll love it. The only down fall is if you are using this area for aftermarket ventilation. I have other style vents that dont use this area.
Knee Pads Good
I have used the SLP vents on the dash and I also have large vents at the sides of the hood so I do not need this area for venting. Anyone on this post that does not think this is a good idea has not tried them yet.
