Hi I have a 2012 rmk pro 800 and I'm getting 100 psi on mag side and 115 on pro side. What is the correct compression for these motors? And also would this be the cause for it coding a de7 code
There's pitting on the head which I have a new one on the way along with new jugs and it destroyed my reeds but everything seems super smooth and in working condition in the crankcaseIf you can't find any damage and the crank turns smoothly, you're probably in the clear. That said, I don't know how a chunk of piston skirt finds it's way out without bouncing off the crank or rod unless it's pretty small - if it does get through the transfer port, then it can get sucked out the exhaust pretty easily. When I ate a piston, part of the crown broke off and somehow went straight out the exhaust without bouncing around and peening the dome like you often see. Obviously that's a big step closer to the exhaust port though. Anyway, I'd recommend a close inspection as well as (ideally) checking crankshaft runout and rod side clearance (you need a dial indicator and feeler gauges for that, but they're not expensive). If you can't find anything, put it back together and don't worry about it.
Just a little over 3000 miles. The lower rod bearing seems very smoothhow many miles on the crank? if you are planning on keeping it i would opt. for a recon crank. if it ate a cyl skirt chances are debris went through that lower rod bearing. you can also have the upper case machined to accept a 13 and newer monoblock. thicker skirts with less chance of that happening again. 3022352 part # of 2012. 3022449 is the number of the 13,14,15 monoblock. i would closely inspect those cases and the oil squirters.
