Seems to me that if you plug hoses (solenoid closed) the ves will work on exhaust pressure against the spring pressure. pre 05 style.
If you do not change spring pressure(spring) valves open at regular rpm (solenoid closed)
If you change spring pressure you can get valves to open sooner/later
If your solenoid is operable there should be no difference due to ecu control
A reflash could change opening parameters.
If your solenoid is malfunctioning (stuck open/sticking) you loose exhaust pressure and opening is little to non existant.
You can check hoses for excessive build up.
That said just plugging them does nothing if the sytem is operating correctly.
Tried it with 5/16 bolts in hoses then caps then attached all in one ride and really saw no improvement....others swear by it???? did not tamper with springs..jmo.
