if the new doo goes 15000 miles.how many poo engines is that
I know not of this slope you speak of??
Hahahahahah!!! Ya good times it was not but the sled did handle it, probably better than I did. Good meeting ya!
Ahh snowest...only place where a Polaris engine lasts 500 miles and a Doo engine that isn't built yet lasts 15,000
****ty deal but read the last paragraph.
http://www.newsminer.com/news/local_news/fairbanks-man-killed-in-avalanche-near-summit-lake/article_d3dc13b4-00f4-11e6-a058-5bd15eac77d3.html
Yet another bash fest again
I love the way my Polaris handles, but I also recognize that they need new pistons on a pretty regular basis. The AXYS will be no different, it will get a new top end over the summer with about 1500 miles on it.
You've been here a whole 2.5 months? You need to do some digging there boy. The statement I was responding to didn't specify "Axys" engine, it states "Polaris" engine.
Sure, cracking "cylinder" skirts has almost mitigated with the '13 MY. But the motor still loses pistons and cranks, up to MY '15. It still has fueling issues, as does the Axys due to the injector/injector placement that causes premature piston wear. I just rebuilt a '15 last week, with this problem. New crank, pistons, injectors at 945 miles.
I believe we will see the continuation of these design issues with the 800 HO '16 MY Axys. We didn't see the real story of the 2011 Pro-Ride RMK until the following season.
All I own are Polaris'. But you guys have got to take you beer blinders off. Get over it, Doo builds a better, reliable sled minus the TRA. Does it work better in the snow, I certainly don't think so. That's why I ride Polaris.
Anybody with any mechanical aptitude can pop the hoods off a Poo and Doo side by side and see the difference. And if you can't see the difference in quality between the 2 sleds, then you need to spend some time working on them.
Mis aligned injectors causing piston wear. now I've heard it all. We're did you come up with that theory?
The fueling issues you refer to might be called epa. Seems epa likes the afr reading of 14.7 to pass. That works very well on a 2 stroke for longevity by the way. . Put an afr gauge on it and you'll see what I'm talking about. Some lean spots on stock ecu fueling.
And your saying a di motor with 200 degrees Fahrenheit higher temps in combustion chamber over an sdi is more reliable?? With no lubrication/cooling to the connecting rods,wrist pin, wrist pin bearing . Heat/ friction is a killer on 2 strokes and the di motor is prone to it.
To say one 2 stroke is more reliable then another is a complete joke. Around here more di motors are down vs the sdi Polaris.
I run Polaris too but see more failures in the di motors from 3000 miles up vs the newer 800 ho. Now that 2 seasons have past for the 800 ho. We're seeing huge milers, 5-6 and 7000 miles on Ontario and Quebec sleds . And the pistons and cylinder are still within tolerances. That's a good thing.although there are failures. Not as many in the 800 ho vs pre 2013 cfi 800's. Does that mean the newer 800 ho is better then another 800 for reliably??
No.
They all break.
Playing the one is better the the other is getting old. It's a 2 stroke.
Heat and friction kill all makes
