pDrive CLUTCH... DISCUSSION... TUNING, CLICKERS, FLYWEIGHTS... PHOTOS AND VIDEOS.
5.00 star(s)
There is oil getting on your clutches Frederick.
I have three race clutches and have have them on two turbo sleds.. Impuse kit has been running over 8 lbs all year and ran flawlessly with toms arms.. It hard to go away to something else when you have success and light weight :eyebrows:
Doubtful anyone will know what the taper on the new 850 is until next fall.
The 850 clutch taper is diff...
You need a RS600 Pdrive clutch to run on a etec 8...
Hey fred, check your scale...the RS TRA clutch is not 4 lbs lighter than std tra7 (both forged, ring gear 1 lb, mov sheave less than 1, machined fixed less than 1, same size and same moving parts) unless your scale shows 14 lbs or less on a stocker??-:face-icon-small-win
IMHO and scale the Pdrive is 1 lb lighter than LW TRA-BJ
Not sure John, my scale is just a cheap old Walmart cooking scale, it only goes to 13lbs.. But I just ran out to the shop and put the stock 15 primary that came with the turbo sled fully loaded..
First picture is 9 lbs 10 ounces and second picture is 5 lbs 10 ounces for a stock primary weight of around 15.5 lbs with ring gear..
My race primary's are machined, titanium fastners, and toms arms and weights:present:
And second picture
Run #3 (blue is as sled was set up w/ TRA clutch
Run # 6 (red, is with PDrive and initial setup.
Very nice Tom, from the looks of the graph the new P drive should solve a few track speed issues around that 35-40 mph mark. And higher mph as well. Nice info!!
That's prey decent gains tom.. If it's going to make that much more to the track, it's worth trying out for next season for the Etec
For a cross-brand comparison... I weighed my Polaris stock P-85 primary, non Electric start (no ring gear)... loaded with spring and 64g weights... 9lbs 7oz. (4.28kg).
A LW cover, Ti bolts/pins and Ti spring would bring that into the mid 8 lb range.
Has anyone weighed a new Summit pDrive (with clicker style flyweights and spring)?
What is the outside sheave diameter of a pDrive and/or TRA?
significant increase , hopefully that equals higher track speeds on the slopes.
It was significant. In actual head to head testing the new P Drive clutch setup pulled the holeshot, and gradually walked away from the other test sled. Both 2016 model Freeride 154" sleds. Both studded type RMSHA tracks.
To date the P Drive has offered better top end speed then anything we have been able to offer from the TRA setups.
That's a 13 percent gain to track hp with the pdrive over stock tra.. Pretty decent gain forsure.. How hard will it be to dial the pdrive in tom on a turbo setup.. Almost a 25 hp gain on a 200hp sled is pretty bigggggggg...
