M
MotoPsycho
not sure you want tighten it up any more kinda like going back towards the red white spring. You only want as much side pressure as needed.I watch a ton of cat guys throw a sno pro green in the secondary and tell me it pulls like a banshee outta the hole only to hit a wall in a hundred feet, too much spring pressure and you cant pull thru it to achieve shift out.
Correct me if I am of an obscure thinking. I have always understood the side pressure to be dictated by the "compression" (squish) force of the spring, while backshift is controlled by the "torsional" (twist) force of the spring. Am I all wet here?
