The green/white/green primary spring didn't make much difference. Going to look at the helix next. Maybe I'll just the clutch kit from Hartman.
What elevation were you riding at Skidooboy?
My take on this is that there is too much tip weight,and the secondary influences the primary too much,and if you try to tighten up the secondary then it over revs,then the tip weight takes over and influences the back shift,I think a weight with more curve and more middle influenced,will produce a more consistant RPM.With the weight so flat it can't move fast enough or far enough to be a true torque sensing weight,,,,great for up shift,,,sh!tty for backshift.
But this is just my opinion.
Can someone post a pic of the weight and tell us where they are grinding? When everyone says the "tip" it makes me think they are grinding the very end of it. If you imagine a straight line through the three holes in the ramp, are you grinding on the very end and perpendicular to this striaght line? I want to try it as my belt is a long ways from the outer edge of the primary.
