my dealer has it. Found out about it today. Also tested the pcv today, at 1400' with jims stock map. Mid range seems to fit completely fixed, top end is still rich, or so it feels. Topping out at about 7900, max i can get for a second or so is 8050. I'll try dropping two grams see if it helps. Also got it to bog pretty good a few times. Not a throw you over the bars bog, just bogged down to to about 7000, throttle out and back in and it was good again. Long wot pulls it seemed to bog if the sled was on end, if it was just over a field then it would come down to about 7900 and stay there. Maybe cause it's got more load if the sled is on end?
Anyway. Back on track, the flash is real and my dealer has flashed two so far.
