hey guys (and maybe gals?),
i have a turbo issue that i can't seem to figure out. when starting out at the beginning of the ride, there is great throttle response and top end. after a while, it gets sloppy on the bottom (doesn't feel like lag; more like too rich) and starts to spit on the top. feels like the det sensor but no code or over-rev. rpms about 7600 ish when the problem starts. here are the sled details:
2011 800 assault w/1600 miles
-snow X piston kit fix installed @ 1200 miles
-re-built turbo @ 1200 miles
-silber 2012 turbo kit @ 11 psi set up to silber install manual recommendations for 9-10K altitude
-stock injectors
-10% enthanol resistor
-boondocker EBC
-sunoco 110 fuel
i'm a pretty good tuner. this is what i know:
-afr is around 15.0 at idle or cruising and 11.5 WOT. and stays the same when it starts spitting on top so it's not a lean condition
-both plugs look good with no signs of deto
-both jugs have good compression
-thought it may be an exhaust valve issue on the bottom end but if it wasn't closing, the top end shouldn't be effected, same if the reeds are chipping
-tried pulling fuel out on the bottom/mid to clean up the bogging with no results
-clutching is all legit (clean, good belt, primary spring not broken)
-no engine codes
it's something that happens when it gets hot;
-fuel pump?
-injectors?
-stator?
-pipe?
also seems to have gotten worse. hopefully, someone can give me some direction. hate to tear it all down but may have to. any help would be greatly appreciated. hopefully, it's just one thing.
thanks again, jeff
-stock injectors
-boondocker EBC
-sunoco 110 fuel
-no engine codes
-fuel pump?
-injectors?
-stator?
-pipe?
thanks again, jeff
