A lot of posibilities have been thrown out there.
When was the last time you cleaned your powervalves, and how often do you clean them?
The reason I ask is because with the amount of miles you have, they should have been cleaned multiple times by now... And the fact that you are unsure of how to inspect the power valve cables leads me to beleive you have not cleaned them?
This is the forst place I would check... If they stick, or if a cable pops off, they will idle fine and run fine just above idle, then fall on its face.
I had a similar "intermitant" problem on my F-7... Turns out, the head of the allen bolt that holds the valve to the cable had broken off... The head of the bolt couldn't go anywhere, but would move around and cause the valve to not fully close at times... Replaced the bolt and it ran great.
My buddies did a similar thing and was throwing the cable off the servo... His had very carboned up power valves.
