Like that....
That is exactly what i want mine to look like. Now, to find a good aluminum welder in the area....
SMF,
Hope you heal quickly. After 30 plus years doing metal fabrication as a career. I have more scar tissue than skin on my hands (might be a slight exaggeration) between cuts, grinder bite abrasions, burns, etc.
P.S. IMO and OSHA as well, Gloves should not be worn while operating any rotating equipment.
The glove had no part in it........
The aluminum piece rammed my hand through with it.
Hindsight is always 20-20
Yeow!
Been there, have 9 fingernails to prove it! Would jokingly call yours a "flesh wound" but the X-ray tells another story.
Keep that sucker clean until the skin heals. Infection is the biggest risk now.
Like I posted earlier, would an exchange program work for doing this mod? It would just cost a little cash flow on the end users part but I could set it up. Where I send you an overstructure that is already fixed in a box with a return label, you take fixed one out and send me your non modified one. The major cost would be a core charge that you would get back when I get your overstructure and verify that it's not bent or broken.
Bryan
Sent from my SM-G928V using Tapatalk
That's was us. Ran into problems with making it simple enough for most people. The pro ride chassis was much friendlier in this department.
It will come down to 2 things
1 - if you absolutely don't want to drill a hole then it's going to get a little pricey on machined parts and it will lose its structural design.
( it is slightly dependant on these, the tubes are thin and need all the boxing/ triangulation they can get. Cut them off and have a bigger guy jump around on them and watch them move a little....leading to fatigue and cracking over time.)
2- if you could care less about drilling some holes it will be easier.
We get opinions both ways on these. I've talked with Sage Crusher and he would have no problems drilling holes cause it's just a hole. Have other locals that I know personally that have major issues putting a hole or 2 in the tunnel.
Bryan
