Lynx/300LX track on matryx
I’ve seen sleds with vibrations suddenly lose all vibrations after replacing the driveshaft.
(No matter what track is on it)
I think some loose manufacturing tolerances are playing around.
Can someone explain to me how they plan to fit a 3.25 lug on these next year? What am I missing?
Ive wondered this as well. With the 3” Lynx track on my boost there is about 1/2” between the lug tip and front cooler. Going to be very tight in there with a 3.25” track. I did use a 3” PC with avids on my last axys, it did vibrate a bit. Personally I think the doo/Lynx 3” performs much better than the 3” PC.
Different cooler design.
Where did you find this info? I've looked through a bunch of the info on this track and can't find anything about a cooler redesign, which seems like a pretty big deal. Also seems like an expensive re-tool for them.
I suspect they are just cramming it into the current tunnel. This smells of the the MY2021 3.5 pitch debacle.
Agree. Although I haven’t tested a 165 yet.
I'm likely one of the 300LX owners this was directed at, ice build up is not my issue, it vibrates immediately out of a heated shop. Still working on figuring out if its a track or clutch issue. Vibation is definitely coming from the clutches... but I think the track and/or drivers MAY be causing it. I'll report back when I get it figured out.
Not a track issue. Was a clutch issue.
They even said it only fits in the 24s. Will not fit in previous models.
Correct. Adjustment in cooler to allow fitment of 325 track in 24 models.
Can a 325 be stuffed in a 22-23 model?..... probably..... but clearance will be MINIMAL and not recommended.
I’d like to see what they changed on the 24’ for the 325 track for tunnel clearance. Can’t believe they’d make a big change in tunnel and/or cooler for it, unless all 24’ mountain sleds are the same and can fit a 325 even if you order a 275.
They said all 24's have been revised.
I assume thats just the mountain segment
Sent from my SM-G998U using Tapatalk
Might be 3/4 of an inch clearance on 2.75. Really minimal if someone tried the 325. My dealer said it's also $1700 for the track. If one doesn't detour people the other will.
Here you go
Talks about cooler tunnel mod in this video also.
