Any insight into how you did it or tools you used?I did it myself.
Just to be clear on these tracks the 2.6 Alpha track above is 5kg heavier than the 3 inch Alpha track. The 2.6 is a 2.86 pitch also where the 3 inch is a 3.5 pitch.I ran the Alpha 146" track on my 9r last season. The grip in these tracks are very good in firmer snow compared to its opponments.
I like the track for my riding style and typical snowconditions we get.
BUT, theres a significant weight difference. The 146" alpah track is actually 5kg heavier then the Serie 6 146". That is whopping 25% heavier then the serie 6 track.
Polaris put alot of effort creating a ligjtweight sled, also with focus on rotational weight.
I will do some back and forth swapping around these 2 tracks this season to see if I can make up my mind.
The owner of Mountain Magic in Edmonton “retired”, meaning that he now works out of his shop at home. He did it for me. If you want one done, I can ask if he’ll do more. It’s not cheap, though. Pretty well the same price as a new track.Which shop did it for you?
More so looking for advice or a how to. I have a spare alpha track that won't work on an Alpha due to broken rods but I think would work on my twin rail turbo Doo as a spare time project.The owner of Mountain Magic in Edmonton “retired”, meaning that he now works out of his shop at home. He did it for me. If you want one done, I can ask if he’ll do more. It’s not cheap, though. Pretty well the same price as a new track.
Measure the width of the drivers, mark it out on the track and cut some holes. Sounds like your track is already damaged so it’s not like you’re going to screw up a brand new track.More so looking for advice or a how to. I have a spare alpha track that won't work on an Alpha due to broken rods but I think would work on my twin rail turbo Doo as a spare time project.
I did make a template out of aluminium. The I used an occilitaing saw (fein saw) to cut out the holes.Any insight into how you did it or tools you used?
Is there a reason why you must remove the alpha clips?I did make a template out of aluminium. The I used an occilitaing saw (fein saw) to cut out the holes.
I do not recommend, as it took me north of 3 hours, and my hands was num for 2 days after spending 3 hr with all that vibration.
you must remove the alpha track clips. I did cut them in two, and resued them by reinstalling them in the new location.
I have the track clip tool from tracks usa.
There is not enough clearance over top of the rear shock to leave them.Is there a reason why you must remove the alpha clips?
The center clips will hit the track shock of the twin rail skid.Is there a reason why you must remove the alpha clips?
Cutting my alpha track.
My track is off my 19. They didn’t have the centre portion on those tracks.That’s exactly how I did mine except I didn’t cut the center portion out. Why did you do that?
