Yes, The clutch feel is stock. That is a great point of the EXP.
“The Rekluse Core EXP Auto-Clutch Is Magical”
– Dirt Bike Magazine
Core EXP just got better – Now with EXP 2.0 Technology™ – Breakthrough in Response, Performance & Tunability! Rekluse Core EXP – Core as in “Hard-Core,” is our award winning premier product. It is the #1 choice for performance minded riders that insist on perfect clutch lever feel that also demand the highest performance and durability available.
The customer will be riding this as his "go to" summer bike, so the EXP will be super super nice for him next summer.
Don't mean to hi-jack the thread, but I have a question about the clutch. My roomate installed one of these on his 2013 KTM 250sx and the clutch pull got noticeably stiffer compared to stock. Are the 300's stiffer than the 250's at the lever when they are stock? I wasn't there to watch when he installed it to see if he got everything right, but he ran it all summer without anything being damaged so i assume it is installed correctly.
what kind of fuel are you going to run?
If the cyls were ported and the ex went up at all and you still have 180psi you're getting fairly substantial. esp too bc bikes on snow get held wide open alot more than on dirt.
@ rush44, the belleville 280 has the same physical measurements as the stock 300 belleville spring. I spoke with Idaho Joe at Rekluse about installing the 280 in the 300. It will add pressure plate force and increase holding power like you would prefer on a high HP bike. I know the 300 at peak HP and TQ when dumping the clutch in a "tree well" will need a ton of spring pressure. Equal to, if not more, than a stock 450F. I will install on this build and report. Negatives = none, positives = firm "lock-up", no slip. hmmmm? I will report back.
Was your bottom end full of a watery oil mix?
Yes it was , I did wash the bike after the ride home, but had an exhaust plug in.and ive cleaned it after every ride not having any problems.
I did have to clear out the airbox a few times from being packed with snow and did see snow dust past the snow filter put didnt thank much of it .
A couple of things. Your 2 stroke has no engine oil like a 4 stroke. Your crank case is bone dry. The only way to inspect it is to pull the cylinder and split the case. There is a separate "isolated" chamber that holds trans fluid for your trans and clutch only. If you got water in the vent line to your trans and it froze over night, you could get frozen up. Also, after you washed it, you could have gotten water behind the reed block feeding the crank? In all the years of snowmobiling, never have seen that. Your bike motor is the same as all the snowmobile engines. They run in the coldest, deepest pow all day, no problem? You don't have engine oil or the issues associated with it. I would definitely bring it in a warm shop after a deep pow day, pull your seat and plastics and dry everything out. I think it was a combo of things, cold pow day, pressure washer, frozen outside. Never have seen that before. I would dry everything out and you should be fine.![]()
The day after a big powder ride and this cold weather my motor was frozen up .
had to put a heater on it for 2 hours to break lose.pulled the pipe dumped it out and im pretty sur the bottom end was full , kick it over a million times to clear out.
bad deal any ideas on this or how to keep this from happening?
got past my snow filter some how ,,
I guess I need a heated shop !
