On a 155 tunnel. Now that would be dopeIce age 162 khaos style.
just talked to Andy at GSR. he does not think it is possible to lengthen the standard FTS shock to work on the khaos.
You just end up with a new shock.
It’s hard to cut anything longer.
I know, but replace the rod with a longer one...
The short track shock is around 1” longer, send andy one of those to shorten to khaos length.
what is this short track shock you speak of?
Did you ever get a chance to see how well the setup works? About an hour away from ordering the raptor setup and a set of good used rails.Ya I think together with the khaos rails and raptor kit is the ultimate combo, or either one independently will be a step in the right direction.
bringing this back up top, very ready to do this, would like some more playfulness if it works well.
I orderered the Raptor Khaos kit --> longer limiter strap, extended FTS rod eyelet, shaft holding tool for $100
163" Ice Age Khaos rails, used Arctic cat 8" wheels
Also installed a 190# RTS spring (Khaos uses a 180#, stock ProRMK RTS is 210#) that I had laying around
It's all installed. With zero traction and the track spinning, its making the front end feel light. We are supposed to get more snow here todayy/ tomorrow. Should have a better report then.
