O
Oregonsledder
Mountainhorse loves the Lords!
I do too!
MH, you are making the assumption that the surfaces were properly prepped before powder coat and I wouldn't make that assumption.
So you'd even use lords say.... on a 13 that your anodizing the boards even tho factory did not on a 13?
This is the point I'm at is why I ask I was just going to rivet back on like factory.
The previous post tell you what you need, but basically, the $40.00 gun and several mixing tips, and the glue. You can go with the glass bead stuff, but I don't think you need it and they don't sell it in the small tubes. I find the non glass bead stuff to work just fine, and it comes in the small tubes. It's pretty easy to work with and after the first purchase you have the gun. They also sell some great plastic fuser that works great for hood repairs.
Well there you go. Did you bond them Ski?
Which post are you referring to?
Does the $40 gun require you to purchase the piece that pushes on the back of the container to force the lords into the mixing tip?
