No, I had some durabilty issues with the kit i had on my proride 800, so removed it and put in a slp stage 3 engine with one of indydans LR cranks.
The BB ran very strong, when it ran, but got tired of wrenching more than riding when the second set of pistons went bad. Since then I have moved on to the axys chassis.
The axys is just so strong and responsive out of the box, that I so far have left the engine stock. But I have a pipe on the way now, these sleds seems to make good power just with one added.
Only thing is that I think the sled looses rpm sometimes om the top end, having the ex valves and everything related checked by dealer next week.
This past weekend, we had a 15 Pro out and a 16 AXYS. The snow was the same both days but the weather changed from dry to damp. Both sleds lost 200-300 RPMS in the damp weather.
I think it is a air pressure sensitivity.
Can you do this on a proride also? I ride some warm days and sure notice the change.
Sent from my SM-G925W8 using Tapatalk
First off those are probably standard correct HP values, AKA basically close to sea level.
As for previous versions of the 860 or so BB for the Poo 800 probably used a piggy-back fuel controller, such as a PC-V. I think BMP will using the Bully Dog GT tuner for their 860. This unit always for a lot better tuning due to more variables are allowed to be changed to fine tune the fuel AND timing maps.
A company called HSK Racing over here (Norway) just dynoed their own 860BB for the axys, 169.3hp, with jaws pipe, rktek head, PCV with the ignition module and slp intake.
Several on snow over here, seems to run good from what I have heard.
And btw, they dynoed a bone stock 800 axys to 142hp, for what its worth.
Yeah right. At what elevation?? . . 14,000 ft hahahaha!!
If not, someone needs to re-calibrate their dyno.
Here is the link to our 860 big bore: http://bikemanperformance.com/snowm...axys-860-big-bore-kit-for-2015-up-800-ho.html
$2495 for the top end kit. Requires our normal single pipe & bully dog GT with our custom tune.. and of course some clutching (our stage 2 clutch kit is recommended). 186-187 on our dyno from mid 150's stock.
Add our y-pipe into the and create another 3-4hp making this a 190-191hp monster! Dyno sheet is in that link above.
-Mike
Looks like 650 for the fuel controller, 500 for the pipe, 400 for clutching, 300 for the can that's required for below 6k' couldn't find a price for the y pipe, I'll guess 200. So around 4500 all in.
It also helps that they give us 10% off, except for the actual big bore kit it self. I believe all of the above mentioned items are eligible for the discount.
I'd put our big bore or even stage 3 bolt-on kit up against any pump gas turbo. The turbo kits we've ridden with that claim "instant power" still will not touch a big bore on low end. In our experience when racing up hill, the turbo will fall behind and it takes a long chute to overcome the naturally aspirated instant power. With us and many others I'm sure... just depends on what you're doing. If it's climbing all day, turbo's work well. If you are playing around in technical areas and want predictable power on tap at any moment... then I'd highly suggest our stage 3 kit or 860 big bore.
We will be offering a complete big bore kit for $4295 which will include: Exchange big bore cylinder (bored, ported, plated), durability kit with Wossner big bore pistons, exhaust valve machining, top case half machining, BMP single pipe, BMP Y-Pipe, Bully Dog GT loaded with our custom 860 tune, Stage 2 adjustable clutch kit.
As said previously: If riding low altitude you will need a big bore muffler as the stock will be restrictive and limit horsepower.
Forum discounts do apply!
-Mike
-Mike
