I never noticed the additional weight of a boosted sled I guess.23 claimed pounds. Night and day on boosted pro vs 850 kaos. You could always tell the difference between the weight of a boosted polaris and stock. Just not this big of a difference. It is kaos geometry vs. Pro. If your boost is a kaos then it's not adjusted right.
It’s probably more the overall change in weight distribution front to rear.You guys really think its the weight that makes the front end feel heavy? I’ve got a hard time believing the 15ish extra pounds would make any noticeable difference unless it were hanging out 10 ft in front of the bumper.
Vohk mentioned some RTS springs were coming from the factory with 1” of extra preload.Do we know if there something wildly different RTS wise from the NA to the Boost?
I never thought there was either until my wife was riding the 11 turbo pro and i was riding the stock 12 pro all day. She said something was wrong with the turbo. I took it and played with it for a while. I was like, wow, you can feel the weight of the turbo when not on the gas. I adjusted the boondockers box and got back to within one number of where i was. It still wasn't right. Finally dawned on me that it was spark plugs. My turbo cat had samething happen once and 12 pro would go through 2 sets a year. Just all of a sudden run like crap. Change plugs and you were golden. I'm sure the 165 boost rides lighter than the 11 turbo but once you get used to easier, such as kaos or alpha, you don't want to go back. Go try riding some older sleds that you thought were awesome in the day and you will think, i can't believe i rode that. Only reason i brought that up was because my wife said she was glad she didn't get the boost and she never thought the old turbos were that heavy. I think they need the kaos geometry. If you don't think they feel a little heavy you never knew what light is.I never noticed the additional weight of a boosted sled I guess.
Swap the rear torque arm from an axys.New update....I loosened the RTS shock about 3/8 inch and tighten FTS about one and a half full turns. In addition, I moved the skis to the inside setting. NIGHT and DAy change difference. The sled handling changed dramatically ...I am 215 without gear. My plan is another half turn on FTS and see. I was about to give up NOW LOVE this sled. Slash tunnel in deep snow is awesome. With Boogie wheels in on New sled, I cannot use my FOX track shocks on boost...I guess the RES would hit wheels....
NGK has had a lot of issues the past few years.Over 200 miles on the sled and one issue. I cracked ceramic on the plug and the tip was missing...concerned but the sled running fine. ran another 25 miles to get back to the cabin. I got a pre det warning about 10 miles before I lost power and knew the plug was cracked. Has anyone used NGK iridium plugs and have thoughts? More expensive but this is my 3 rd cracked NGK in two years.
IDK
Iridium is quite different from platinum in strength, performance, durability, and degree of melting point. Iridium is arguably eight times stronger and six times harder than platinum. It has a higher melting point of about 700 degrees compared to platinum.
Platinum spark plugs wear out faster than iridium spark plugs. Iridium plugs are said to be more durable compared to platinum plugs up to 25% more.
https://rxmechanic.com/iridium-vs-platinum/
Yep, your doo is obviously superior…..From what I see is there are alot of guys selling theirs. Must not be very impressed.
That is what I was thinking, but he is a taller guy and loves it.The na is set up wrong. Night and day lighter feel compared to boost
