I have been making snowmobile front suspensions for the past 12 years and in that time I have learned a lot…. Some good and a lot of bad. One thing about front suspensions is they are the first thing to a coalition and take a bigger pounding than any other part on the sled. If they are to strong they will take out our bulkhead. If they are to light then they will brake under normal use. <O
</O
If Skinz is truly using a ½” rod end on the bottom a-arm then that is to light duty and will not matter what quality of joint they use. They will bend and brake over time even if you do not hit anything. They must be a 5/8” rod end to be strong enough. We use 4140 chrome Molly steel that is heat treated and hard chromed in our front ends and they are plenty strong. To fix the problem they are going to have to figure out how to put in 5/8” rod end or the problem will continue.<O
This is going to be a big safety issue if they do not.
<O
Skinz is a top notch company that we do a lot of business with and I am sure they will make it rite with every customer.<O
Allen <O
Timbersled Products<O
<O
Allen <O
