So I ride a IQR 800, ves, twins, head, pods, tons of vents, bored carbs, the whole deal. Sled rips until I ride super deep snow. with 12"-18" sled runs great, EGT's 1000-1050. Once I saw 1100 EGT on a firmer day on a long sidehill WFO climb. I'm okay with the sled running a bit cooler/richer up top, but could that be my problem?
The last two days it has been deep, 3ft of pow, basically bottomless. Sled still runs great UNTIL I get out into deep untracked snow, once it starts coming over the hood and handlebars it bogs, and gets worse and worse till it can't power it's self to move any more, If I hold it wide open it still can't move it's self, egt's will read anywhere from 450-650. Now if I were to jump into someones tracks and I can keep it from doing this, get the egt's back hot, once I get it cleared out I can jump back into the deep again but then the problem will come back, sometimes rather quick sometimes but if I keep it really screaming it won't happen for a 20-30 seconds and I can get some decent carving in, if I hit I really deep spot bbooooogggggg. Really a pain in a$$.
I have a good snow deflector for the exhaust, that is not the problem, I've experimented with it plenty, bigger and smaller. Same problem.
Could I be heat sinking? I don't think I am because it's never really getting that hot.
Running out of air? Don't know how to test for this? But I don't think this is it, all the vents get covered with snow but I'm sure it's not air tight. I have vented, sidepanels, shock towers, hood, headlights, and tach.
I honestly think I'm just jetted too rich, could this be the case? The load of the deep snow and rich jetting overwhelming the motor? It just seems odd that the motor would run richer on a deep cold 12*day then it does on a 35* firm day based off my egt temps that is, guess it's because of the lack of air flow causing warmer under the hood temps on the deep days?
Ideas? It's deep and I want to ride.
current jetting with pods and PAR 13.6 head
45 pilots
air screws 1.75 out
fuel screws 1.5 out (need to double check)
needle - 9dfh10-57 on the 2nd clip from top
290 mains
Sorry for the novel!
45 pilots
air screws 1.75 out
290 mains
