After running the 40* with 2.45 gears.
Everything is for 10k elevation
Throttle response want what I thought, but the backshift was really good. But the upshift was not good.
Fighting to gain speed. In the trees it would pull good track speed and worked great but it just back shifted to hard.
Got to thinking about it and with the gear up trying to run tip weight in the mds it changed the shift timing.
With gears it works better to load the middle to get more throttle response, with stock gears the tip works better.
So this time I went with 2.45 gears, 48* helix but installed a 200/280 sw spring. Stock 180/240.
120/310 primary, sled bolt in tip, sorry bolt in middle. Worked ok. 7450rpm.
Pulled to weight, worked better, I like the throttle response but rpm was 7500 to 7800.
But it still ran better across the range but not optimal anywhere.
I'm going to play around until I hit rpm with the 48* just to see what it does, then try the 43 with different springs.
So far the easiest that I know works good is the 43* a slight or no gear up. MDS weights, tip loaded with 120/285 spring. Replace stock secondary spring with sw 180/240, stock spring goes bad in a few hundred miles.
I may wind up with a 45* or who knows what,
