There was some ice and snow that had accumulated around the base of the belt drive in the pan
This did not seem to pose a problem for the belt or gearing.
Right now, Polaris does not have plans to offer different gear/belt combos according to their engineers. But that may change in the season to come.
The belt drive sprockets are electroless nickel plated for durability.
The center to center measurement remains the same as previous years... Tunnel clearance, which I've been critical of in the past, because of the "Sierra Cement" that I ride in, remains unchanged.
The belt was made in conjunction with Gates and is the same carbon fiber construction as that used in high hp V-twin primary and secondary drives.
Polaris tested the belt under extreme conditions during the development of the drive and assured us all that even if any teeth on the belt were stripped off... that the sled would still retain braking and be able to be driven out of the back country.... they also said that a severe load that would probably cause other problems wold have to encountered to damage the belt. Service life from the belt was said to be in the thousands of miles before replacement was necessary.
I have no idea on cost, but this drive system would be able to be retrofit to MY 11 and 12 sleds. In fact, the demonstration bare chassis on display had the new system fit to the previous year driveshaft.
