20 lbs for 100 horse, sounds like a good trade to me. Engine looks great.
If anyone is running the old-style UBR housing please note: If the mag housing touchs the bulkhead it will come loose. If it comes loose (can and does even if it doesn't hit the bulkhead) it will continue to come loose and cause huge issues (like Darrin's). The only fix is to Dowl it and use some epoxy (in a very small amount) if it is bad enough. Brad's new design (as I have said before) is a huge leap in improving this area. So for anyone building a motor right now or thinking about it. Two things, 1- buy a new crank through Brad or have IndyDan build you one. 2- If you need the space (like in a Edge or IQR) go with Brad's new mag housing (also available through Indy Specialty). Do not go "cheap skate" on these two items. Do yourself a favor and discuss this with either one of these two guys, you will not be misled!!!!
Ouch!!! is that $3k Canadian?![]()
has anyone else had a chronic mag housing falling off issue? Mine has the old UBR style housing. I've tried everything short of welding the damn thing. Everything clears it, theres no contact with pipes/bulkhead etc but it still falls off almost every trip. Seriously considering tacking it there...
been using red loctite, lots of torque on the bolts, 1104 on mating surfaces, cleaning all threads before re assemley etc doing everything right and it still wont stay put.
Has anybody considered using a AC diamond drive with mechanical reverse? I am going to build a 1200 iqr when i get all the parts needed.
Would be really nice to have reverse on it. The whole non reverse bit brings back bad memories when I was lifting my gen2 rmk around.
But I am worried that the DD wont hold up with the power.
I've read in this post that some use a older polaris chaincase with manual reverse, but i guess those chaincases are a bit short to run with large drivers and tracks with tall lugs.
I am trying to get all the requiered parts to build a 1200 wc in a iqr chassie.
Will start off running tm40 carbs.
Is the carb flanges i need #1253566?
I have a extra mikuni fuel pump from a 02 800 ves motor, can I use it? Should i get another on and hook up in parallel and T everything together?
