Some progres with my 1050. Hope to get it started in a few weeks.
Thanks to everybody for this thread. Lots of good info here.
Anyone have the avenger install manual? I dont have the install directions. As far as power mine was hooked up with red to yellow and black to chassis under the brown wire. Thanks for the gearing advice all. And yes I was thinking of going mechanical reverse. I have read where several people have done it with no problems so I figured what the heck.
CS high altitude 800 pipes have a 29mm Inside Diameter STINGER. I like the 3 inch silencer diameter for noise reduction.
CS low alititude 800 pipes have the 32mm ID STINGERS.
I just got off the phone with Crankshop and according to the lady I talked to the low alt pipe have 29mm stingers.
Just thought I would clear this up. Anyone else have info about CS stinger sizes? Did I get the wrong info from CS?
I am just passing along what Crankshop told me on the phone today.
I thought the same thing, more air at low alt so you would need a bigger stinger.
Anyone have the name of the pipe guy to talk to there. I talked to a lady and she is the one that told me that 29mm stingers were for low alt. She answered the phone and I asked to talk to someone about pipes and she didnt transfer me to anyone.
They (CS) told me the same thing. That 29mm is low altitude on the new stampings.
When I got my pipes, they had 27mm stingers, they said those were race pipes, so I opened mine to 29.
Would be nice to experiment with bigger stinger, but don't want to mess up the crome.
Where should I be pulling power from for my Avenger 3? P1 in the setup mode is set to #1 and the RPM is reading 9.33 at idle. If I change P1 through the entire scale 1-20 it reduces the RPM number. It is an 1160 Triple, with 650 Ultra electrics, I have a brown, yellow, and Yellow/Red coming from the stator. I have Brown and Yellow red going to brown on voltage reg. and Yellow to Yellow on VR.
I have the old connector for the Avenger with only Red and Black wires. The manual says to pull from the lighting coil... don't have one.
Thanks,
the 650 regs are junk.
I used two cat regulators wired together, works perfect!
could the voltage reg be the wrong one? i was having the same problem till the guage no longer turned on when started as well as the led tail light stopped working at the same time?
i traced my wiring, cleaned up extra wire simplified routing. then started the motor and the guage worhed for a few seconds and then quit again? still no tail light.
so i switched the xcr 800 regulator for the 800 twin one. the guage wouldnt do the auto on but would now read very low rpm instead of nothing. after a couple seconds it may have failed as well cause it stopped reading any rpm
what kind of volts should be coming out of it? also what is the best reg to be using? i have heard of cat regs but which one (year size or model)? are they all the same?
