using stock edge wiring harness!
hope there's a voltage regulator there someplace
Brad, you mean that if I turn the plate to full advanced it will be around 16 @ 8000?
Hey guys. Almost done with my 2007 Iq 1200. Big thanks to Brad and Lynn for being so gratious with their knowledge. I buttoned it up and it fired, man it sounds good. Couldn't ride it cuz I'm waiting for a power-jet.
Anyway, I used the new EGT Ultradash (udx6) and I can't get it to turn on. Also, the PIAA's won't start either. I hooked the EGT to the yellow(+) and brown in the headlight pod and the PIAA's to the yellow/red(+) and brown. If I use a test light I have power all the time to yellow-brown and to the yellow/red-brown when the high beam is on (as planned). The two other wires in the hood pod are green (low beam) and blk/white (temp sender). The guy at EGT told me I HAD to be hooked to the lighting coil which I believe I am. It's just odd that both items aren't working. I do have tail/brake and hot hand/thumb warmers. This is an Ultra CDI with the stock 2007 IQ440 mod chassis and regulator(s).
I also have a small coolant leak somewhere which I hope is just a spring clamp (unfortunately under the carbs). There is no sweet coolant smell from the exhaust but is there something I should be looking right at? This was John O's old mill, he hit a tree with it.
Also, the coolant is not circulating yet though I've been burping and filling it won't take off. Might be the pump or just f**** bubbles? This was a dry chassis.
Sorry for the length, it's been a few days of dicking around.
Jim Foran
So basiclly pretty much turn it full advanced as there is where one wants to be? I think SLP recommended 16 @ 8000 for the RMK. Of course, will double check that its around 16 @ 8000 when I get it fired up, as it can be diffrent curves depending of the year of the ignition and manufacturing diffs.
jim you have to have the red yellow and the yellow connected to each other for the lighing coil to work . so hook them together and try that. Brad
Could be air trapped in the rear tail section of the tunnel/coolers. Can be a real pain to get out, you need to elevate the front alot to get the air out.
I recommend that anyone using the xcr ignition to play close attention to part throttle operation at first. Particularly if you use the stock rack carbs. You can burn it down in the 1/4-1/2 throttle range if you don't run egts and watch it.
