Hello,buy a new stator, call Brad i think he can help you with a new one.
Good luck![]()
stock '03 800 rmk and no extra ground,other then stockwhat about your grounds? I have the cdi to motor then a ground strap from the motor to the chassis. What voltage reg you runnin?
buy the one for the electronics you use. I have a 89 650 reg. and never had a problem. there cheap and there ment for what your running.
Im not sure but I bet that your reg isnt right for your setup.
the stator that is in now is Brads'
I still think it is the stator,i have had this problem on both polaris and a/c.
Try it!!![]()
Funny ive seen the same prob with the CDI box on the domestic twins, start run fine for a few seconds then die.
Stators Ive seen do this but only when they are warm with a good heat soak (after riding for a couple miles). Then they loose spark most of the time or just run terrible, but only when they are hot!
I still think it is the stator, almost impossible........but i think you have two that not workToday I put the original stator that came with motor,started it up and it ran
about 2 minutes,long enough to think that it might work,took it outof the shop
rode it about 250-300'and it started stalling and died,got it going enough to get back to the shop.okay it runs when cold warms up and doesn't,so CDI or
STATOR,or both?
Woody, it does come with carbs-40mm rack mikunis with power jets, a custom air box, recoil, waterpump, water rail. I have the one piece head and 2 sets of domes, 13.4 and 15.0 I will sell the motor running with the 650 indy ignition for $3800. I also have a xcr ignition, new hub fly wheel, remapped cdi, all coils and mounts, wire harness also. I can sell it anyway any one wants. I have dino sheets from this motor from this summer, it made 252 hp and 161 ft lbs on 20% race gas and 13.4 compression domes.
I have to admit i love this sled, but I have an addiction and I just want more hp.
I think I am jumping on the turbo boat and going to turbo an 09 m1000. 340 hp sounds mighty nice.
I buy the engine !!!!!!! mail me and we talk thereWoody, it does come with carbs-40mm rack mikunis with power jets, a custom air box, recoil, waterpump, water rail. I have the one piece head and 2 sets of domes, 13.4 and 15.0 I will sell the motor running with the 650 indy ignition for $3800. I also have a xcr ignition, new hub fly wheel, remapped cdi, all coils and mounts, wire harness also. I can sell it anyway any one wants. I have dino sheets from this motor from this summer, it made 252 hp and 161 ft lbs on 20% race gas and 13.4 compression domes.
