Have you got any pics of your mounting Ninja plumber
I run a gen II chassis so it it different than most of you guys.
I am also using it just for ice racing. This is what currently works for me.
Rear torque stop
Front torque link and mag housing torque stop
The bolt on the PTO side going threw the motor plate had
been increase to 7/16.
I have the motor plate drilled to match bolt.
I don't ride the sled for hours on end so vibration is not a problem for us.
I have not had any issues with the mag housing coming loose. I have run
it like this for 3 seasons now. I believe because I have the motor mounted
so good that there is not an excessive amount of push on the housing.
If I run with broken mounts it could be a problem.
I did break the 7/16 bolt once this year. I am currently going to increase
the bolt size to 1/2" while my motor is out.
As most of you know there is only one bolt hole on the front
PTO side.
I have not broken this mount. It has held up extremely well. I believe because the link is angled
down it helps stop the upward movement of the engine a lot.
Lynn posted a while back the part numbers for the link. for those that
are interested here they are:
bulkhead bracket 1013777
bolts to hold bracket 7517632
rubber coated rod end link torque limiter 3021411
