Climate change
Do you know when they started putting in catalytic converters they would burn so hot that they would glow and in some cases start fires. Solution retard the engine to run like ****.
Also do you know this DEF fluid that diesels need to run on or go in limp mode is injected on the down side of the turbo because they run better on newer vehicles, ,you know the exhaust pipe before the catalytic converter.
It's all a lie, why is it that no matter where you live elevation wise vehicles all run the same? Explain that to a sled head at 10,000'.
Yeah, a neighbor farmer lost his new Chivy truck 40 yrs ago when his cat caught corn stalks/fodder a'fire.
Sad, and if I remember right it had nothing to do with the cats but dry conditions, global warming.
Those that had AC kept them cranked making the engine work more creating more heat radiating up threw the cab not to mention the load on the engine tanked the mileage, you couldn't even slide under to change oil till the damn thing cooled down.
Things are much better now, the vehicle just ignites requiring the fire department new ways to put out environmentally safe toxins.
Now that's logic
The one in Buffalo, what do you think that grade log chain is? 43? would only make sense for transporting but what they just did Are You F.....S.....?
Global warming you say?
Yeah, that's not a good app for chain eh?
The chains should have been on the tires.
I am not only surprised that they were able to run dozer's up that pile of snow, but the fact that they were piling it at all.
In The Soo (Michigan) - they just dump it in the St. Mary's River and their done with it.
But The Soo (Ontario) I have seen them make big piles like this - on the N side of town.
Don't know if they dump it in the river on the south side or not.
It's piled here also like that, bigger cities have no place to just dump. The areas that this is done is something the greenies should dial into. Maybe they would stop using brine and to make it even worse they add salt to the sand. The brine dilutes and attaches to fine particles and crystalizes than add carbide studs, the greenies love studs, that peal up the recycled asphalt is really good for the lungs come spring time dust.
This is what comes off the pickup every time I wash it and that's on average once a week. Only plus is it doesn't take the windshields out like the pit run pee gravel they use to use.IMG_20221115_175512948_HDR.jpg
