D
devilrmk
Well, had a problem with the cpi unit, lowered oil level in tank to 1/2 a quart and never had a problem after, but I am on the flats.
Anytie there is boost it can blow by the bearings in the turbo and push into the tank. long venting lines and one way chaeck valves are std issue..
a bov might help some to.
Gus
boost lower than the waste gate spring pressure is leaks or too rich.. if you rode it without burning it down its rich..lol
Gus
Not worried about my low boost #, I changed the spring in the wastegate to lower my initial boost. Wasn't sure where it would be at. Glad its at 4 because I can keep it down on rides I don't need it and turn it up when I want.
It was probably just a bit on the rich side, I adjusted the powerjets just to the point it would run clean.
I should be fine just moving my vent to the front of the tank. My tank capacity is about 1.5qts I figured on running it at 1qt.
The check valve, is that the antiroll over valve you talked about earlier in the thread?
A regular type check valve would block the pressure in along with the oil...
