I do have remote adjusters for power jets never need to open hood again pm me if interested in some.
Rob
Tony, you can get big float valves for the cutlers from wahl bros.
Once you have your sled running, do another test for reference to fuel pressure and float response to load.
. with engine idleing, slowly increase fuel presssure tilll the idle changes. Now drop pressure back 2 - 3 psi. Make note of the pressure at which the idle dropped.
Now you know the point in bosst build where your pump pressure overcomes the float valve .
One other test to synch carbs to each other fuel response and volume wise is to run the pump with engine OFF, taking note of fuel level thru the powerjet line and vent lines.( best to do with airbox off and carbs in reed boots. ) slowly raise pressure till you see the fuel level move in th epower jet line and or vent lines. Make sure you check each carb closly as if one is ahead of the other you need to adress why.. A lagging float or one the doesn't sink within 1-2 psi of the other is gonna be a issue with unexpected leanouts.
Ya, it is too bad that great resources like Gus are being chased away so that money can be skimmed.
Ill see ya on the other web pages Gus. Thanks for all the help!
Jake
Lectrons are to leaky , they spew fuel from every seem when pressurized.
I would like to use them but its not worth it monitarily.
the other issue with them under pressure is needle outlet wear. the sharp flat on the needle wears into the carb body and it goes, rich to lean as you wear it more and more.
turbo sizing for that rev ,, 2860/2871 . aero 53 biggest they have. 66 is better.
mitsu car turbos are barley adequate for 220 hp.
