BINGO !!!
good response,,Jake.
the overlap of circuits can vary widely. some run 3 turns out ofn powerjets, and small mains, others 1 turn out and larger mains. There is NO blanket answer to this, its more effected by clutching and on aeros vain orientation.
Using the vacum side of the aero controller will cause a completetly diferent curve than NOT using it.
fixed schroll housings with wrong ar's can go to one side or the other also.
evaluate the rich or lean spot as far as rpm, load and throttle psoition, then you can make a decision as to what ciruct or circuits need adressing. many time we lean one only to enrichen another so as to not create another bad spot.
Gus
back in the early 80's we ran the third powerjet in the charger or tube, havent used that set up since then . no gains only harder overall tunign and consistency,, but ,,,,,, to each his own.!
no ONE set up is best for everyone.
