B
bin sledin
New member
just installed a hmr garet turbo on my 08 rmk shift 600 running 50/50 any tips on set up and power jet adjustments what shouldbe my max egt any imput wouldbe greatly appreciated
i got my sled running today and it starts and runs fine. im running 2psi of fuel pressure on a 1:1 regulator. The issue is that after i ran the sled on the stand i was able to build a couple psi of boost and so i know everything is working. a couple hours later i went to start the sled and there was fuel running out of the pipe. it happened once before and i think it was because i had the choke on to start the sled and the fuel pump on and it bypassed the jets and just filled up the case. but this time i had never used the choke. im thinking i have a needle thats not seating all the way and letting fuel bleed off when the motor is not on. any help on this would be great. or how to prevent this. i did notice once i got it started again it works best if dont have the fuel pump on for a while till its warm, and when i go to shut off the sled, let it run for a while with the fuel pump off to bleed off all the pressure.
just installed a hmr garet turbo on my 08 rmk shift 600 running 50/50 any tips on set up and power jet adjustments what shouldbe my max egt any imput wouldbe greatly appreciated![]()
Run your power jets out at least 3 or 4 turns to start. Some say full open. Either way if it blubbers and doesn't really produce boost then its rich, turn your power jets down a bit at a time just until it cleans up. Not sure about EGT's, I don't look at guages very often.
Make damn sure that waste gate is closed full shut too.....
