Lord's adhesive, the rumored bonding agent of choice for the driveshafts, apparently has a 50 psi handling shear strength that may occur at between 1 and 2 hours. Lord's does not appear to list the 7 day strength, ultimate strength, yield strength or any other properties that can be used to evaluate the suitability of this product for the polaris driveshaft situaton.
The driveshaft has stress reversals occurring at the bonded joint from the upward drive belt tension, and also from the rearward track tension. Steel requires working strength to be about 10x the stress reversal forces, in order to have been properly designed. I estimate the drive belt tension causes about + or -3000 psi shear on the bonded joint. I estimate the track tension causes a + or -500 psi shear on the bonded joint. The same bonded joint also has engine torque caused shear of about 250 psi, that acts at right angles to the belt and track tension caused shear. Given the mysteriousness of the industrial grade Lord's adhesive, it does not appear at this time, that their products has either the short or long term strength to hold up to normal snowmobile operating conditions. Once the adhesive bond fails, then the belt tension tends to pry the steel insert out of the aluminum center driveshaft section, since there is no mechanical backup like a continuous steel driveshaft.
