Getting a gopro video of the clutches in action on the problem belt eaters would be a good idea,
After having the secondary off mine and looking over all the engine mounts,
I would bet things are moving/flexing around quite a bit!
Things that could flex
1. Thick rubber engine mounts
2. flimsy looking engine mount brackets
3. very flimsy secondary bracket.
4. Bulkheads, the pictures ive seen of the broken ones are catastophic! Maybe under load hits are exploding them?
Or unknown cracked bulkheads? Again flexing..
Have dealers been Swapping primary clutch's with known non belt eater?
After checking
1. Belt alignment
2. Clutching issues..
Binding springs, rollers, correct pin weight and springs for altitude..
3. Bulkhead damage
4. Excessive engine movement
I know trapped heat is an issue..
But having a good functioning clutch system
Would almost make the heat issue moot
I'm a bit shocked that no real fix has been found for this issue yet..
IMO there must be multiple reasons..
1.Primary clutch
2.Alignment issue's due to lots of flex
3.???
Things Ive been thinking about..
After checking
1. Belt alignment
3. Bulkhead damage
1.Primary clutch
3.???
