Bar forward.... Kincaid style
Just a FYI for the guys going 3" post forward. I'm 6 feet tall an first put on 2.5" riser an found it a lil low on trail (hunch back). So next size I could get was 4". Put that on it it lasted one day an I was pushed too far back again an sled was totally unpredictable an washed out with feet back. Back down to 2.5" for rest of all last season (30+ riding days in some of the deepest snow I've seen in Revy) and I wouldn't ever go taller than the 2.5". It's just plain awesome. I was so close to selling mine an getting a Poo because of the side hill washout till I did this. Now I'm completely impressed!!
The next one we do I'm going to cut the T off and drop it a bit. I've got to check notes but I think we said 1.75"... which would take care of your issue. Putting the T down makes it so you can then run a 4" again, and then have the 4-6" adjustable on there which would be really nice from an ergo standpoint.
The gussets that Wildchild uses would be nice to add to the T top btw... going to find something like that when the next one comes along.
Sent from my A200 using Tapatalk
Got out yesterday & I took a measurement off the post fwd setup, looks like we could get away with 1.75 & get a shortened allen wrench in there.
Im going to be running the zbros adj. post delete and was wondering what guys were finding to be the best riser to get Im about 5'11 so would a 4" be enough or should I just go with the 4-6 adj. riser from Rox?
Thanks
I have the zbroz telescopic delete and 6" rise on my handlebars. I am going for a 4" or a 2" this winter :)
BTW, I am 183 cm, and I like my bars low for pretty much any kind of driving.
But you just have to try out some risers and feel what is right for YOU.
so if a guy were to convert from a telescopic bar to the fixed hrc bars there would be an improvement in bar position? meaning that the hcr post is further forward than the telescopic?
Also bar forward kits do not work with the HCR post?
NO, the fixed post mounts in the same place, but will allow you to rotate riser slightly forward, what it will be is lower and will pivot on impact
So in theory the T top mod with the adapter is just as good then? I love that I can push my bars more forward after I went for the zbroz adapter and telescopic delete :D
Ok thanks guys. I think I might try the HCR post. I ride my telescopic ones one notch up from the bottom, what size risers would you recommend to get the bars about the same height?
Here's one way...
3" c3 post fwd with pro taper bars and controls relocated to console. Looking for a decent handlebar mounted tether to take up the gap between brake lever and where the controls used to be. I tried the 2" riser but that was only to see if the bars felt better forward or not, this is the correct way to do the bars IMO. Cleans them up and much stronger, yet allows them to fold when you take them to the chest...or the upper thighs.
The 4" riser the HCR post comes with I figured as ~2 clicks up from the bottom. I tried the 2" riser and it was a little low for me. I like my bars as low as possible while still being comfortable. I ended up with a 3" RSI riser. Worked great last year. I'm about 5' 11".
Protaper also come with a rise to them, bars may be high but I prefer them where I can stand and my elbows are slightly bent
I've never looked close enough at the bottom end of the post to see what kind of bearing/bushing it has down there. Any binding by moving the top of the post forward?
