I did the BDX telescopic delete and that is no doubt the best mod i have done! Can have the bars forward or backward or follow the post.
Can also have lower riser!
Is that pretty much the same as the HCR fixed post?
Almost....I have used both and now use the HCR fixed post, way more stable and tightens everything up, the HCR fixed riser is tighter than aftermarket as well, just my 2 cents, for about the same money you can have a better post without cutting your sled, the next guy might want a telescopic post
I do like this set up.
I don't know why you guys are calling it a ball buster...has anybody really ever hit their balls on this set up...I doubt it!....its not a bmx bike
Dave, with the HCR fixed post does it allow you to pivot the bars forward some without messing up the steering swing too bad? I really liked where the "Kincaid Bar Forward" Rox risers felt like, just don't like the ball buster of a steering post and the slop associated with the adjustable post.
Those are the main reasons I was looking at the C3 post forward kit.
Depends on height maybe? I'm 6'4" and it is right at ball level. With the stock setup your legs and everything kind of would hit at the same time, but with the rox risers on there the post is what you will hit first right between your legs.
I've never had an engine in my pickup blow but I still change the oil in it......
Better to take precautions before something bad happens. To each his own. I ran this setup and liked it waay better over stock just looking to do something better on my new sled.
I will be seeing Rob Kincaid and Dave McClure again at Hay Days this year
I will be sure to ask them....my guess is probably not
...sounds like more fake drama on SW
X2 - 6'4" also and I guarantee you, at our height, your nuts will take the brunt of the blow. I really liked the rox riser setup but not at the expense of the boys. Have everything to put the post forward kit on, will tackle that this summer.
Gives Bust A Nut a new meaning..
Is the C3 less stressful on steering parts ? Or all the same..
Is it more easy to do with the BDX hood?
Some of us ride hard enough that we crash at times. (and SOME of us ride hard enough to crash ALL the time)
If hitting the bars is something that seems "fake" to you... I suggest you try harder.
But do ask the guys that get paid to ride this setup... you're sure to get a COMPLETELY unbiased answer.
Btw, I hit the bars a couple times a month, and I've hit them hard enough to bend them a stack of times in the last few years. Most of the time you're further back so the rotation of you eating bars actually puts them into the chest or neck area, or at times the face... does this make that nasty metal bump being the closest thing to you better in some way, since it's not actually your nuts? Broken ribs are fun, right?
Make sure to report back to us...
