I get what everyone is saying about ice build up and it's effects on balance, but that ice is building up on a rotating part.
So for the most part it should "balancing itslef" to a certain degree.
This is why you never feel the imbalance but rather the tightness of the track and the "crouching" of your suspesnion as that ice ball increases in diameter.
Unless you stop and a little water drips on one side from the coolers and then freezes up, and then you can feel it.
I balance things somewhat for a living, every electric motor rotor, up to 500hp gets balanced at the plant, every pump shaft, every trubine shaft, to the gram inch....GRAM.
With RPM ranges from 1750 (motors, pumps) to 3600, Gas and steam turbines.
Including the ABB 11DN Rotor which whieghs 38 tons, which is balacned to 13 mils displacement. Now, 38 tons, spinning at 3600 RPM now effectively weighs 9.5 pounds or so on the journal bearing.
Centrifugal forces are amazing.
The PRO has a shaft that I will estiamte to about 10 pounds? spinning at what 8350 RPM?, add a gram to one side at that speed and watch the fun.
I will leave the math to the mathmagicians.
Once again IMHO, and as always, I welcome the argumentt stating otherwise.
Misspelled to hell but I gotta' roll....(fly)
