Not true... there are guys with 170 and a little over 200 that have broken now also, it's a bad deal, I was feeling pretty confident this would not be too bad, you'd know fairly soon if it was good or not, till I heard about those. Hope poo gets her figured out, I am sure they will but at what cost of lost time on the snow??? Only time will tell.I was told if the drive shaft is gonna break on these 13 pros, its going to go out in ten miles or less. Just a little FYI on what i was told..
Gzzzz.the drivers in the original pictures don't even look like they have even touched a track....must not have been very many miles b/4 the grenade went off.
and will it affect the balance of the shaft?
Where its placed on the shaft will also effect balance as well. You can factor in balance of the billet pieces but i guarantee both those bolts don't weight the exact same. Will it be off far enough to cause damage? Who knows.ABSOLUTELY!
Not to mention the snow and ice build up throwing off the balance, I bet the drivers aren't balanced perfectly or weigh the same either... So I think a clamp around the driveshaft aint gonna matter much.
I see more cause for failure due to the additional imbalance than without it.
Yes, the snow, ice, dirt, etc. all affect the balance, but why would start out with a known imbalance? Personally I'll chance the raw glued shaft over any of these patches. If the glue is set up- you should be golden! If the glue is soft then no clamp is going to help. If you insist on a bandaid to give you a warm fuzzy feeling the best of the three I've seen is NM's- plastic collar with a steel clamp band machined from a stock plastic driver. But it is your sled, I see more cause for failure due to the additional imbalance than without it.
Because all those rotating parts are factory balanced right....................![]()
Depends. Location matters more that weight. The shaft is so long. You have drivers in set locations already... The shaft is factory balanced... I would be curious as to how you guys are compensating for the new balance points by adding weight to this shaft in unspecified locations.
Have fun with a raw glue shaft when it breaks bud. All these fixes are addressing the problem and its not just a warm fuzzy felling. And the billet on is within a few g when cut in half and it spinning 1.8inch from centre so there is going to me no vibration. Maybe for you trail riders going mach 10 but for mountain riders puling 50mile track speeds at best it isn't a worry. And how do you say no clamp will help if the glue is soft explain logically dont just speak out your *** give me a reasonable explanation. I am tired of all the people that just say stuff with know knowledge its like you dont have a say in the real world so they cum on here and run there mouth about stuff they no nothing about.
