lots of valid comments on the alphas good/bad points....i had a 165 alpha last year with a little over 1k miles on it, traded for a 20 HC 165 this year, have a little over 200 miles on it (can, belt drive, clutching)....i do think a person needs to be careful in hard snow on steep side hills as the track can get away from you if it hits a hard spot, tendency to want to spit me off at a bad time...steep climbs on harder snow also takes concentration and not being too proud to back off and turn out because of the nose coming up too high....in soft snow the sled is clearly superior to anything else i've ridden, handling, traction, you name it....every sled has it's good and bad characteristics, as we know, and i haven't found the perfect one yet....but, the alpha is the closest so far...an example from yesterday....i was sitting at the bottom of one of our challenging climb hills with an 850 doo, a two year old summit both with 165 3" tracks and a two year old poo with 155 2.6 track (i think)...elevation was a little over 10k with 20" of new over about 4' of older snow....i wasn't riding with these guys, but i watched them make several tries at the hill...the hill kind of has two stages to it, with a short steep part, slight level off and the rest of it long and steep with cornices and windblown crust at the top....the poo tried several times to get over the first hill, but mostly failed, finally turning side hill to barely struggle over, getting a little speed back before making an unimpressive stab at the big part....both doos' made it over the first hill, both poaching tracks, as the poo did also, then making good runs at the steep hill before turning out about 2/3 the way up...i was riding by myself and usually don't do big hills when alone, but at least there was someone there if it got serious...anyway, i picked a spot where there were no tracks, with only a couple of small trees to turn around as opposed to just taking a straight shot up the hill, the alpha easily went up the first part of the hill in untracked snow, and then climbed in untracked snow to where the windblown snow just under the cornices made me uncomfortable in going further before turning out...got a big thumbs up when i got back down, nobody else even attempted my untracked line....that's what i like most about the alpha, the fun factor in deep snow, riding what i've got the rest of the time..
