I have 2 different 21 Khaos 850’s. One is a 163 2.6 the other is a 165 2.75. Both have the QD2 gearing.
I have the BD weights in the 163. The SLP magnum force in the 165. The 163 seems snappier off the bottom end, more lively. The 165 is lazier feeling. The 165 seems like more of a tractor though. Just keeps going.
Obviously 2 different tracks so not apples to apples.
I find the BD weights easier to deal with being capsules instead of different little set screws. Also they load the weights differently. The SLP loads from the tip to the heel, while the BD loads from the heel to the tip.
So as you increase weight in each sled it’s a different shift curve. The lighter you go in the SLP the more tip biased it is. As you add weight it shifts it more towards the mid/heel.
While the BD starts at the heel and adds weight towards the mid/ tip as you go.
I had trouble getting the BD where I wanted it. It was over revving a touch with the one capsule and under with the other. I ended up adding a little stiffer primary spring and it’s in the sweet spot now.
So I would say the BD is easier to work with, less fussing around with little set screws, harder to fine tune. SLP is easier to fine tune but easier to drop a weight and lose. Happy with both set ups and would use either again.
