I junked the Stock weights in my Adapt and tossed in a set of the Snypr weights-more adjustments now than what's on the market - especially when it comes to the Adapt clutch.
Some of the spec's show 85/225 stock springs- but mine came with 85/255.
I run alot of throttle pass the power valves open and the Adapt is quicker to respond get the rpm back up- engagement is the same as the Team rpm's
We run 9,000' and keeping the rpm around 8300-and so far the Snyper weights are all what they sell them to be...-one bonus is you don't have to run the silly shims on each side of the weight.
I like the open magnet holes, in addition with top adjustable screws to place the weight in to get the pull where you want it.... pretty simple and there is also plugs with the kit to off set pin depth in the weight.
So far 300 miles and the adapt is passing the test's once it's set up for elevation- 2019 165
I am going to add more mid weight ( running 59.2 grams now) to pull harder & back shift quicker with the helix I just put in there and got rid of the stock 48* in the secondary.
I am running the BMP Y and Fat Daddy Single, with stock ECM programming ( not the stop ride flash) but the original tune, that is the best Cat came with IMHO
Not an issue with the Snypr weights I am told- They are made to replace the silly shims (thrust washers)Watch for casting wear if you aren't running the thrust washers ("the silly shims" as you put it).
Cam arms rotate (flange bearing or not) and the cast aluminum is softer than the hardened steel thrust washer, which can lead to wear.
The US spec M sleds were produced with 85/225 springs and the Uncalibrated ADAPT clutch part number 0746-933 description says it comes with the 85/225 but all the ones we have received have the 85/255 like yours.I junked the Stock weights in my Adapt and tossed in a set of the Snypr weights-more adjustments now than what's on the market - especially when it comes to the Adapt clutch.
Now that a head scratcher for sure- Yeah we just got in 16 more clutches Uncalibrated and all were the 85/255The US spec M sleds were produced with 85/225 springs and the Uncalibrated ADAPT clutch part number 0746-933 description says it comes with the 85/225 but all the ones we have received have the 85/255 like yours.
What Elevation you running at?Alright so first ride with the adapt, I'm over revving with the 255 spring and the... 61/62g weights? I was about 83-8400 rpm, so I'm wondering with the 225 spring will drop me a good 200 rpm... Or if not then I may look at welding some weight to the tips of the factory weights...
Forgot to add that hey, most my riding is 5-7000, I was at about 5500 when she was pulling 8400 rpmWhat Elevation you running at?
I could never get the MSD weights to work above 10K, even after removing weight from base weight, per Steve's instructionVern- I do find out that they ( adapt) are zingy-
As far as the residue you have on your adapt- there is quite a bit of protective coating on the clutch sheaves- I know in your post that you scotch cleaned the sheaves.
I follow up with brake cleaner and let it atomize to a nice dry face. It's possible you didn't get it all of and when things got hot, it flung what was missed on the clutch guard and belly pan as described.
I have not had any issues with clients that switched to the adapt prior to a good scrub down..
The BMP snypr weights are tough to tune at 9,000 +it doesn't like the lower magnets at our nose bleed elevations
