F
firecat225
Where did you find a 140/280? Dalton?This will be my next set up.
65.8g 140/280
50-46.20 with a 140/230.
65.8g 140/280
Venom makes a 140/215 that's the one I was meaning. Green/blueI have that spring as well. The 230 final will be to much spring pressure for the 42 degree angle.
Straight 48 on a mountain sled for high altitudes? Thats just crazy. I would go for straight 42 or 40 even.I was in Revelstoke for 2 days in deep fresh snow and the sled still bogged with the new flash. With some revised clutching, the BOG went away. Was able to better the bottom end response. I feel like the stock 62s with the straight 48 has a weird hesitation on the low end which seems to cause the BOG. With revised clutching it didn't Bog all day.
40 is way too low even on the 800 with a variety of springs. I tried a 43 on the ascender 800 and it was terrible at 11k ft. Would have instant backshift and rev, but overall did not pull hard and was consistently 5mph less track speed in deep pow. I ended up with a 46 straight and it was great IMO. I feel this 858 will pull a 48 fine from how mine has felt so far. Time will tell. Cat and Polaris pull helix angles totally different from each other.
Most people forget that Cat uses a larger driver then polaris or doo. 7 tooth 3.5P vs 6 tooth 3.5P. Even tho cat has a lower gear ratio - the 1-1 shift factory is close to the same as polaris but higher then doo.Helix angle and what a sled will pull is related to a bunch of different things: power output, spring rate, helix diameter, clutch diameter, final gear ratio, driver diameter, track load (lug and length), etc. The Arctic Cat secondary uses a pretty large diameter helix in comparison to some other designs. Cat also has a low final drive ratio of 2.63. This is quite a bit lower than the Polaris QD ratios. So a steeper helix than one might think seems to be warranted. On the old Ascender chassis dropping to a 45 degree seemed popular. 858 might pull the 48 fine in some conditions.
That being said the stock clutching calibration seems to be off the mark for a lot of people.
When testing in Revy, the 858 cant even get passed half shift with the 48 helix and horrible track speeds.40 is way too low even on the 800 with a variety of springs. I tried a 43 on the ascender 800 and it was terrible at 11k ft. Would have instant backshift and rev, but overall did not pull hard and was consistently 5mph less track speed in deep pow. I ended up with a 46 straight and it was great IMO. I feel this 858 will pull a 48 fine from how mine has felt so far. Time will tell. Cat and Polaris pull helix angles totally different from each other.
Gearing up is the wrong direction. Your loosing efficiency by not getting closer to 1-1 shift.Ran a variation of combo helix's/ spring rates last year @ 10,00' on the Ascender- Best I liked Geared to 2.42 and ran a cut helix 54/48.30 with a 155/240.
Pulled like a horse and upshift decent and backshift was fast! Worked pretty good and waiting to at least try that secondary in the 858-to see how it likes it.
Didn't have to mess with my primary after that
@Reddragon800 , would you recommend this setup for 6k-8k elevation? Or something a bit different? I believe Revy is a bit lower in elevation...This is what i tried. have another set up to test for the next trip.
64.6G weights, 130/250
46-42.36 with a 155/220
Bottom end was much better. Top end was the same, but had no BOG.
I didn't realize Cat used bigger drivers, although I'd never had a reason to dig into it; that's a big advantage. Avid is making a drop and roll kit for Axys/Matryx sleds - it seems there are significant gains in rolling resistance and snow evacuation - and I have to wonder if Polaris will incorporate some amount of drop and roll eventually. Anyway, you do have to incorporate the gear up factor with a bigger driver; you wouldn't want to go from a 6t drive to a 7t without a significant gear down. Seems Polaris and Cat are pretty similarly geared when you take the driver into account: 21" (driver circumference) divided by 2.27 (gear ratio) = 9.25 for Polaris; 24.5 / 2.63 = 9.31 for Cat. So effectively, Cat has the same final drive ratio, despite being the lower gearing.Most people forget that Cat uses a larger driver then polaris or doo. 7 tooth 3.5P vs 6 tooth 3.5P. Even tho cat has a lower gear ratio - the 1-1 shift factory is close to the same as polaris but higher then doo.
A straight helix never works well in a mountain sled. A multi angle will perform better in all conditions.
Good visual of the difference at the 7:00 mark in this video:I didn't realize Cat used bigger drivers, although I'd never had a reason to dig into it; that's a big advantage. Avid is making a drop and roll kit for Axys/Matryx sleds - it seems there are significant gains in rolling resistance and snow evacuation - and I have to wonder if Polaris will incorporate some amount of drop and roll eventually. Anyway, you do have to incorporate the gear up factor with a bigger driver; you wouldn't want to go from a 6t drive to a 7t without a significant gear down. Seems Polaris and Cat are pretty similarly geared when you take the driver into account: 21" (driver circumference) divided by 2.27 (gear ratio) = 9.25 for Polaris; 24.5 / 2.63 = 9.31 for Cat. So effectively, Cat has the same final drive ratio, despite being the lower gearing.
Gearing can offer as much gain as clutching, maybe more. Higher elevation calls for gearing down since the engine doesn't have the power to shift the clutches out as far. More low-speed, on/off throttle riding also calls for gear down since it helps with the initial pull. And low elevation and more speed and WOT could call for a gear up. Trouble is, with belt drives you've got few or no options other than an expensive aftermarket kit, and even chain drives can cost hundreds to change around.
