Driver
Second year with Turbo R and it has been a solid engine. Close to zero problems on my sled or my friends rides. But theres always some things that small % of riders might get involved with. Here is a list of problems that I have seen or heard for troubleshooting purposes:
1. Rave servo motor (actuator) failing
- Sudden rpm drops
- RPM fading or inconsistent
- Wont give fault codes
- Brp has updated part number several times, so we know that there has been more issuses in general
- Fix by replacing the servo motor
2. Wastegate servo motor (actuator) failing
- No boost, goes to limp mode
- Will give out fault code P0245 and maybe some others too
- Its the same servo motor as is used with rave, so yeah
3. Bad fuel pump & blocked filters
- RPM fading on longer pulls
- Replace the pump or filters
4. Reeds
- Engine idling is weird and inconsistent
- Weaker midrange power and and slower throttle response, sled might need more pulls to start
- Fix by replacing the reeds
5. Engine backfiring
- ECU cant read out maps for the injectors
- Backfiring, feeling of engine "icing" on midrange
- Fix by rewriting (flashing) maps for the injectors with buds
6. Engine wont pull properly on warm spring conditions
- Flyback voltage compensation has not been enabled from ECU
- RPM fades on warm conditions, general lack of power
- Fix by enabling Flyback Voltage Compensation with buds
There migth be more that I cant remeber atm. I know there has been lots of faulty ECU´s and injectors between 2020-2022 but havent heard that many issues with 2023+.
- Sudden rpm drops
4. Reeds
